Have you considered applying a few plies of the surface veil before infusion? It is normally used to create a resin rich interface to prevent the print through from the fabric or even breather might work.
Tried getting some data through VESC but it never works… Should get a proper logger.
Went out again and got better at taking off. I had to really gently apply the throttle while accelerating and it was a lot easier to maintain the board leveled. These are some rough data points from the remote:
20kmh - 1000w ( close to stall)
25kmh - 1500w
30kmh - 2000w ( max. speed I get with 6in pitch and cool esc)
Beautiful design! Regarding Vesc, are you having issues with receiving telemetry (Metr pro?) through carbon board?
This is actually a pretty common approach. There isn’t a need to vacuum infused the epoxy though. Just paint a nice thick coat on to seal the MDF, then CNC. Then you can always spray a light coat after that and polish.
Thanks Andrii for the detailed reply.
So Duratec: low viscosity sealer, polyester primer and finish with vinyl ester gloss topcoat.
Thanks! I only get telemetry to my remote at the moment, VESC itself can somehow record logs but I believe it needs an SD card. I might purchase the iLogger or smth out there as well. Also the hatch is made of a thick fibergalss sheet so I get great connection at all times.
Yes, but if you don’t need class A surface finish then you can stop after primer sand the orange peel with 180-400 ish ( wet ), compound it, apply wax ( non-silicone) and spray PVA. Important: You must have the solid primer surface with no MDF showing off, otherwise it will suck the air in when you vacuum it.
Or if you can do an envelope bag then you could simply apply plastic tape over your mold surface and infuse that. Just remember to wrap the sharp corners with a breather to prevent making holes in your bag.
I love composite fabrication for having so many ways to achieve the same result, just don’t like the chemicals ![]()
Where are you putting your phone when logging vesc data. lots of us use it. I put the phone inside with the battery.
Don’t carry the phone with me just yet. My hatch is normally closed, so I would probably need an external bag…
Here are some sneak pics of the data from VX3 ( no esc fan) . The throttle had very little range, so I adjusted the curve based on my current settings. Now 0-75% throttle is 0-50 A ( my speed range ).
I also installed 80mm fan under my esc and the temp never got over 45c.
@Andrii Congratulations on your beautiful work. I have hundreds of questions.
- Are you using current control? Why this -100% natural curve? Have you tried linear?
- How much power is necessary for “takeoff”?
- On your first board, the motor was aligned with the front wing. I see that you changed to a more usual approach. Why?
Thanks! Still a work in progress but it is taking shape slowly. Shoot them all, I would love to answer.
I am using Current control. It was determined that close to stall I am using 20A and about 50A at max. speed with this setup, which gives the useful range of ~15% between 10 and 25 throttle input. That’s a small range and it is hard to have adequate control over your speed. ( See graph below )
Changing the exponential gain to -5 changes the throttle curve to more preferable settings with the useful range of ~45% between 25-70 throttle input. ( See graph below )
It is not ideal but the best I can get for now. It would be nice to switch back to Duty Cycle control as it feels more intuitive.
These are the equations for the throttle curve where x is the current and c is the exp gain.
During the take-off the the power jumps up to 4 kw but not for too long in my case.
I decided to go with off the off-the-shelf wing setup and having the motor on the mast is the least problematic solution.
Unfortunately, during the last session, I noticed the water inside the VX3 screen. It is my second VX3 remote, as the first one had the same problem but Flipsky agreed to replace it.
I took it apart and noticed a few cracks in the corner of the transparent plastic case for the TFT , which could have leaked from there.
I removed the screen, filled the case with UV-stable epoxy, put it back to fully soak and applied a coat of RTV silicone around the case.
I am pretty sure that you can set the full throttle current to a lower value. Maybe 50A or a litte bit more. This way linear would have a more precise control.
About the wing: Do you have any positive attack angle between front wing and the board? Any negative angle on the stabilizer?
You are right, I should get away with 100A ( it goes up to 4kw during the take-off).
The wing I designed had 2.5 deg AoA as it would appear to be most efficient in my Reynolds number range and the stab had spacers to change AoA.
With these Gong wings, I don’t know.
I am using a kite surf duotone wing. But i pretty sure it has AoA Zero and I have to adjust it with shims. Having problems to take off and mantain steady.
Duotone Spirit Surf 1500cm²
I will try to add +2deg on the front wing. And maybe -2 on the stab.
Can you describe the problem with the take-off more in detail?
Steady in terms of roll or pitch?
What stab area is it?
@Andrii
Both pitch and roll are “unstable”, i have some experience with kite and foil.
Some videos of a frient : https://www.instagram.com/reel/C9-5P4fJ5wuV_0VUsth0Zut8wFt4o_Q3GyiNuo0/?igsh=N2szOHJpYzdyZnBr
@windego
Front wing 1500cm² (no shim) Stab 250cm² (1,5deg shim)
Flipsky 65161
Flipsky FSESC 75300
13s 27Ah 18650 HG2
Daly 100A BMS
Tested both with original flipsky propeller and a 3d printed True Glide Propeller
I have same motor with flite prop on 85cm gong v2 mast. Using the curve xl 1400cm2 and the xxl stab 355cms is ok for me. With the smaller suggested stab 322 it is more twitchy. Originally I got the smaller one of 275cm2 and I was having big problems.
I have the L wing coming as well as the stab extender to see how that all works. In your case I suspect a bigger stab would help like it did me. I think kitefoil setups may have inherent stabilty coming from hanging on to the kite…not sure abiut that just a guess.
