Flipsky 6384 adaptor for new model motor
Hi, has anyone created a adaptor to FD hub 3D file to match the new 6384 (with the hump)? My adaptor from the previous model doesn’t fit so before attempting to create one I thought I’d check . Thanks!
Bump, looking for the same type of adaptor for the new model motor.
https://foil.zone/uploads/default/original/3X/4/c/4cefc910544ffe16efd4c9e3ab94c34101c0a636.jpeg
This fella seemed to have made one.
@OBecian Here is a link for one I made and used:
thanks so much, really appreciate it!
this works with the old gen 1 foil drive assist hub with plastic propellers right? thank you!!
@OBecian I used for 3 blade foildrive prop but believe as they FD props are all interchangeable it will work on the 2 blade.
