Flipsky 65220 motor
Physics can’t lie…the more weight you are moving, the more energy you have to introduce.
I am looking for a new setup, as the current is “outdoor”, using a normal board and having the battery and VESC in a case on top of it.
Next version will be with a new board and battery inside the board etc…
From the logs with that version and anticipating few improvement, a smaller motor like the 6384 can be (refer to JeffM v7 project).
To stop polluting Hsyn post, I am also considering the 65220 motor including the 75100 VESC as it is saving all the stuff related to the cooling of the electronic.
10 AWG battery wires are small but they will be cooled so capable to handle the higher current during take off.
I keep an eye on your project Hsyn and thank you for testing and sharing !
I wasn’t implying that your theory of “lighter is better” was incorrect. However I have had a friend who is substantially heavier than me ride my board successfully so in practical terms I believe that small weight alterations have no visible impact on ride performance on a full Efoil - non pumping rig.
To stick to this topic I don’t understand why someone would choose the 65220 integrated 75100 over the tried and true combo of 65161/75200.
It’s been pointed out that the 65220 setup has a greater potential for heat related failure and would be a more challenging repair, it’s also lower spec so logically less capable if required. The cost isn’t much different either.
I wish you success in your new build. I also began with a Frankenboard rig and then transitioned to a mainstream design and it made a massive improvement in ride quality and enjoyment :grinning:
I went from 75200 to 75100—smaller, still tons of power. Now eyeing 65220 for easy setup—no water pipes or extras needed (my ESC stays outside the battery box, like in my pics).
Pavel, how do you waterproof the data connections (uart, ppm, usb… with your 75100 exposed to water? I have looked at your build but cant see those connections.
@agua4fun, I didn’t use connectors. The Bluetooth and remote modules are soldered to the ESC and sealed in a large connector box.
Please see the image in this post:
Russian­­­­͏­­­ - EFOIL.builders / Builds - FOIL.zone
The USB connector does not need to be waterproof because it does not have power wires inside. And I cut it off because I do not use it.
If you have any additional questions, please don’t hesitate to ask, I’m always happy to answer.
What do you mean, usb connectors have 5v, com1, com2 and gnd, it can’t be exposed to water
I mean it does not have 5v wire inside, because it is not a host port. It serves a different purpose, not providing power to connected devices.
Hi, has anyone tried the 65220 yet?
Salt/water bridging the pins and corroding the plating is still an issue. It shouldn’t be exposed to water.
Of course, you can protect them from water if you want.
Do you still think there is a live power wire there?
Yes, I do.
Will be part of my next project in progress
Hi!
I’m building a custom e-SUP project using the Flipsky 65220 motor with integrated ESC, and I need help clarifying some important technical questions before placing the final order.
1. Motor Cable Extension (Battery to ESC side):
  • I want to place the battery at the front of the board, which means extending the DC power cables to about 4 meters.
  • What is the default wire gauge used in the 65220 motor?
  • Can you factory-extend the DC cables to 4 meters for me?
  • If yes, can they be made with a thicker gauge (e.g. 8 AWG or 6 AWG), since 4 AWG is too thick?
  • Can you also place the cables inside a protective waterproof sleeve for durability and safety?
    • The standard wire gauge is 10 AWG, but this may cause losses over 4 meters. Can you upgrade to thicker wires (e.g., 6 AWG or similar) to reduce voltage drop and heat?
    • Can you install these wires with proper waterproof shielding and place them in a sealed sheath (or harness) for protection?
  1. Can I also order from you all required accessories for this wire extension — connectors, terminals, waterproof sleeves, shrink tubing, etc.?
  2. I won’t be purchasing a battery or charger — I’m building my own custom pack (50–70Ah). This means I’ll need the fastest shipping method possible without dangerous goods restrictions.
    • What’s the fastest shipping option to Ukraine available in this case, and how many days does it take?
4. Accessories:
  • Do you recommend any optional accessory kits (terminals, anti-spark plugs, sleeves, glands, wires, etc.) to include with the order?
5. Remote Control:
  • I’d like to try the VX5 remote with this motor.
  • Can you confirm what’s included in the VX5 package?
  • Is it fully compatible with the integrated ESC in the 65220 and supports telemetry?
6. Shaft & Propeller Compatibility:
  • Is the shaft of the 65220 motor threaded only, or do you offer a splined version?
  • If yes, can I choose that option when ordering?
  • Do you offer a 2-blade high-efficiency propeller compatible with 65220 (especially for SUP use)?
  • Or could you recommend a reliable supplier of such a propeller?
I have a few more technical questions before finalizing the order:
  1. Could you confirm whether the 65220 motor includes a temperature sensor and whether the VX5 remote can display telemetry like motor temperature, battery voltage, and current?
  2. Does the VX5 remote support integration with external BMS data (e.g. SOC, errors, voltage)?
  3. Does the 65220 motor have any signal cables in addition to the main power cables?
  4. What are the peak and continuous current ratings observed in real-world usage of the 65220 motor?
  5. How are the motor cables sealed—are they routed through waterproof braided sleeving or just standard jacketed wire?
  6. What type of shaft does the 65220 motor use—threaded only, or is a splined shaft version available?
  7. Can I purchase connectors, terminals, waterproof cable sleeving, and other wiring accessories directly from you?
  8. What type of connectors are pre-installed on the motor side and recommended on the battery side (for high current use)?
  9. Can you provide a rough estimate for shipping time to Ukraine if I place my order this week?
Thank you very much!
Anyone know the best settings for the 65220 used with the Maytec V3 remote? Mine keeps cutting out.
Did you ever finish this project? Would you be willing to share your design? I’m working on something similar.
Hey did you maybe get any response for that? I am aiming same VX5 and this motor setup…
Anyone else that tested this combo 65220? It has been out for a year now and only little to no reviews.
Those who use the Flipsky 65220 Engine, please share your experiences with us.
https://es.aliexpress.com/item/1005010465987941.html?gatewayAdapt=glo2esp Has anyone tried this motor? It’s not cheap, so is it reliable?
Hi, I have been trying for days to connect my Flipsky 65220 to a FlipskeyVX3 remote and cannot seem to get it to connect. It does not come with a UART connection cable only a PPM and they VESC set up with the PPM did not work as well as the NRF connection. Can anyone pass advice on how to connect the VX3 to the 65220?
It is pretty impossible to say with no further information.
Set VX3 to PPM, connect to ppm input of VESC, run input wizard on VESC.
If the signal does reach VESC, this will work.
The 65220 is a motor so you can’t connect the remote to it. :grinning:
The vx3 connects to a VESC or ESC that connects to the motor
The VX3 comes with a bag of cables that includes UART.
