Hi everyone,
I’m trying to build my direct drive efoil and today I found a new motor. What do you think in comparison with flipsky 65161 120kV?
Let me know your opinion!
Hi everyone,
Hi Gianmarco,
no really new and the cables are on the wrong side
Mike
Isn’t here anyone who used this motor? I also want to know how it is compared to the 65161 120kv. It is half the weight and should be enought power for efoiling. Also the price is lower. But I don’t understand how you mount it to a foil.
It might be a good candidate for a foil assist. I wouldn’t use it on std efoil though…
Why? From my experience 3kW Peak and 2kW continuous is enough for foiling.
That’s very dependant on what wing you use. A lot of guys run at around 5kw when they accelerate fast or use smaller wings on take-off. I’ve pushed up to 7.5kw at times…
Yeah sure you CAN pull that much power, but its not mandatory. I don’t intended to start a discussion about power demand, I want info on the motor
I saw a short video of a guy using this one as a trolling motor for a small boat, he fried that motor after a day or two, could be his fault, but from what I’ve noticed is that these are low quality motors, seals are bad, the magnet wires are all over the place, I don’t know, it could be that the one he got was faulty from the factory or damaged during shipping, you don’t know until you try.
Max current 70A, continous power 2kW. Could work but is on the low end, better to have some reserve. In choppy conditions, you might need more than 3kW to get on the board. If you use this motor, better limmit the current in VESC, otherwise you might burn it.
I bought one of these, as it seems an easier starter option for my foildrive-ish diy project. Partly because i don’t need to figure out how to attach a prop.
I was thinking of half-a$$ing a connection bolting to my mast track, behind my tuttle mast. This image makes me LOL as that is roughly what I was thinking. It ain’t gonna be pretty … but maybe it will work.
Mhh. Seams that this motor is far from ideal. What a pitty, he lighter and cheaper then his big brother. Would be exactly what I needed when it would be more convenient to mount it.
Ordered the 150kV version now as they have M4 holes on the backplate now. So easy mounting
Still a pity about the shaft…
Ok, have the motor now. Looks like advertised. Comes with prop and splints
Funfact: ist NOT 150kV, but 130kV (Flipsky wrote that in email to me and also my measurements result in 130kV)
Internal resistance:
eRPM / 3 = real RPM (6 Poles?)
Weight about 1.3kg with cables
No load current about 1.5 to 1.7A on 44V (Battery Current)
Quite hard to turn shaft by hand, lots of friction
Runs smooth and quiet on my desk. No difference if in water mug or not
UP NEXT: Water thrust test…
Crazy high IR …
Usually yes : nb of pairs of poles so 3 , just check knowing kv , voltage , the rpm of load
Hard to turn … the magnetic force is made by the iron stator … nothing to say , some manufacturers made stator without iron holder , move freely …
Looking forward to your tests numbers , especially rpm drop under load
If you run on low amps, it doesn’t matter that much. More important is that the motor was only 200€ shipped.
Its not the magnetic forces I talk about. I think it’s the seal that make the friction.
I just would imagine with motor spec IR could be lower
You are probably right about friction and seal , but still very hard to tell without measuring with / without seal , magnetic force vs seal and wet seal …
I recall loosing 50w by seal on my first set up ( brand new , oiled but dry , full rpm, off load )
Sooo, I did some Tests.
The bundled prop is totally useless with this motor. It needs a much smaller one.
I limited the motor current ( not battery current!) to 100A with the VESC because of the high internal resistance of the motor. P = R x I^2 , so 0,080Ohm with cables equals 800W
way to much, I know, but need the high limit to get enough thrust to get on the foil (not tested yet XD)
So best prop I tested so far was a 120mm 3 Blade with a pitch of 60mm. Other bigger diameter seem to be too big and produce to little RPM at static thrust, resulting in most of the power beeing just burned via the internal resistance. My goal is to get the highest RPM with the 100A limit and still put out 3kW power. Meaning that I get more then 2kW transferred to the prop.
As I will get speed, the current will drop anyways. I still don’t know how much and what pitch of a prop is the best. But I have a lot of different props printed and will test them all.
