I was looking to get to get some help wiring my 75200 watercooled ESC. The ESC came with a bundle of wires that i assume are for the receiver however I’m not sure which ones to use for the receiver since there appear to be multiple options.
What kind of receiver are you using? If it is a traditional rc type receiver, it goes in the 3 pin slot, red black and white, Like mine here. Mine is a 75/100, but I think they are otherwise the same.
Phase filtering is not available for Flipsky ESC75100 and 75200!
Please turn off the phase filter function and choose "false" in vesc_tool when
use firmware version on or above 5.3 (VESC_TOOL 3.01). Without turning
off the phase filter will result in esc damage. Please do not restore the default
parameters when using the wizard interface.
If you have a simple remote, it should look like this.
My next build will use VESC firmware 5.3 first VESC FW version to allow the use of a magnetic kill switch (normally closed) connected between 7-3.3V and 7-ADC1 set to HIGH in VESC-tool.
Phase filtering disabled on this 75200 version.
