Here are some details I was able to obtain from the Flipsky chat in case anyone is interested in this new motor. It does have a 55mm stator. My sense is the flat shape of the motor casing will not be good for foil assist? Is a Saite 130kv a better choice than this for a foil assist?
I was thinking to pair this with an actual Foil Drive folding three blade propeller but was concerned that the shape of the motor casing may not be ideal for that configuration. You think its a good combo?
I requested a photo from Flipsky will post here if they send it to me. ps everything above was sent to me through the text chat box on the Flipsky website, I don’t actually have one of these motors yet.
I know Saite is a great motor and in another class then the generic BUAV 6384 but one reason I ended up buying this Flipsky was based on its ability to operate with higher voltage range. Also, in the US they have 12% off now for 4th July weekend.
One notable thing, they run the cable out inline instead of out the side. but I just made a special nano pod to allow the cable out the top if I wanted that.
The motor has ceramic bearings and a circlip so it will be interesting to see if it needs to be opened or whether it can just be flushed in fresh water for cleaning. I should hopefully run it soon, I just need to get my battery back together.
I got the 6374 140kv, but it feels MUCH better and heavier than the Maytech offering.
