Fliteboard prop alternative to FR?
The best is to find a friend with a metal lathe or going in a metalic workshop to avoid futur vibrations at 4500t/mn …
I 've got a drill press but I would not use itif I was you …the lathe is the only way to drill really in the center …
thank you Thierry, I will search that around me
I just bought fliteboard prop, and I have flipsky 65161 motor with 12mm threaded shaft, did you drill the hole of the shaft to 5mm to put the fliteboard pin (delvierd with the propeller, 5mm diameter pin) or did you buy a 4mm diameter pin with the right length ?
I’m going to drill with a vertical drill the fliteboard prop, I thought I was supposed to drill at 12mm to get the prop on 65161 flipsky motor, and not 12.5mm, are you sure it is 12,5mm ?
Nicolas
I’m going to drill with a vertical drill the fliteboard prop, I thought I was supposed to drill at 12mm to get the prop on 65161 flipsky motor, is it right ?
Nicolas
I would adapt the pin instead of drilling out the pin hole. Either use a 4mmm pin with a bit of play or lathe a pin from 2 pieces, like this (diameter 3/5mm):
There will be a new folding prop kit for waydoo efoils coming soon… It fits on 12mm shafts, so it will be adoptable on other motors as well :wink:
What you easiest do is to buy an adjustable reamer kit, they can be found cheaply, normally threee reamers are needed to span between 10-12mm hole adjustments. It’s easy, produces a round, centered hole and you do it in steps until the propeller fits snugly on the axle. 12.5 mm hole diameter is too large.
Thanks, very clear, I will buy a reamer kit
just released a new prop. this time a folding one.
Do we have some data sets for the Mantafoils V3 prop (metr.at, …) ? How does the 3 blade version compare to the folding two blade ?
My solution to drilling out the bore of the flite prop to accept a 12mm shaft of the 65161. The 3d print keeps the drill and prop aligned. All you need is a 12mm drill bit, a battery drill and the print. Iv tested it in the water and it seems perfectly balanced.
https://www.printables.com/model/583026-flite-prop-drill-guide
deepvee.de has become sealectric.de
Here the Flite prop at 35.70€ incl 19% Vat, 30€ exVat
Flite Ersatzteile | Sealectric
There seems to have been a price alignment: here 30/36€ ex/incVat too from the south of France. This same prop was 21€ incVat in Jan 2021…
@Calebleemcd …cool idea…do u have an .stl version?
Cheers
K
The 3mf file is available on printables just convert it, but your slicer will read in the 3mf the same as a stl.
