I would like to thank everyone on this forum for all of the posts. I would have never attempted to build a foil assist if it wasn’t for this site. I decided after a successful first build I would post my build list and experiences in the hopes someone else gets inspired like I did.
I own a foil drive assist plus and love it. I wanted to take on a foil assist diy of my own but backed out a few times. My goal with this project is to get a more powerful assist than the foil drive assist so that I can foil on smaller wings. I’m 185lbs and I need a 1400cm wing to foil comfortably. I’m riding waves but when I’m not I like to stay on foil to ride back out. I can foil on my 1040cm wing but the throttle is close to 100% and I don’t get much time to fly 20-25mins.
Here is my build list
Motor - Flipsky 6384 waterproof - https://flipsky.net/products/flipsky-waterproof-brushless-dc-6384-motor-140kv-4200w-for-surfing-boat-underwater-thruster-hydro-efoil?gad_source=1&gclid=Cj0KCQiA4rK8BhD7ARIsAFe5LXIyahOT5L_IcoLLDkMtCgEHaOEQ8WLMpv2F2h2UBGiEClt2Wme4MxgaAgbVEALw_wcB
Flipsky foldable prop 4.8 - https://flipsky.net/collections/propellers/products/flipsky-4-8-inches-2-blade-folded-propeller-nylon-motor-boat-propellers-electric-engine-outboard-propeller-for-boat-kayak-submarine-efoil-surf-yacht
Remote - Flipsky V3 - Link
Box
ESC - Flycolor 160A Xcross HV3 - Link
Waterproof Box - 11x7.5x5.5 - TICONN Outdoor Electrical Box Waterproof, ABS IP67 Junction Box Enclosure | 11"x7.5"x5.5", Weatherproof Impact-Resistant Housing, Mounting Plate and Wall Brackets Included, Easy Wall Mounting - Amazon.com
8 gauge silicone wire 10 feet -
Mast Clamp. Bent a 1/4 piece of aluminum and a fiberglass puck on the back held together with bolts.
3d Printed a shell to go over it an cover it up.
Battery - currently using a foil drive 8s3p battery to test. On order have 2 6s3p batteries I am planning on running in series for 12s3p. MBoards - DIY Electric Skateboard Parts - Build an Electric Skateboard
Assembly steps. I cut a hole in the box the size of the ESC and used 3M 5200 to attach the heat sink to the outside of the box. The heat sink is larger than the hold cut by roughly 1/2". Then attached the ESC to the heat sink using thermal glue.
The box has a raised floor, I cut some away to make a strap to hold the battery
Also 3d printed a partition to split the battery side from the ESC and wiring side.
3d printed a mast cable guide to make a slimmer profile in the water. 8 guage wire was too thick and causing issues with air travelling down to the prop, so I split the 3 wires out and placed them one behind the other this solved that issue.
BLHEI 32 settings
First ride.
I was shocked to find that first ride out everything worked like a charm. Tons of power, more than my foil drive assist plus using the same battery. I could foil on a 1400cm wing at about half power. I took it out flat water for about 25 min and was at 40% battery remaining. That was all e-foiling even though this is really an assist. I would say efficiency is the same as foil drive if not a little better. Much better than I was hoping with the flipsky folding propeller.
Current issues.
When I am on power and the propeller comes out of the water I lost all lift and the board needs to drop back down to the water for me to recover. I’m not sure if this is the propeller or maybe that my pod isn’t perfectly smooth. It’s very dramatic where as the foil drive just buzzes the prop but you don’t drop off your lift. I compared the 2 foil props (foil drive vs flipsky) and besides flipsky having more pitch the props are very similar. I have ordered a propeller king folding prop that should be here soon so it will be interesting to see if this solves the issue.
Thanks again please let me know if you have any advice on the build or have an questions.
