Foil assist with 6384/6374 Flipsky, wings (full set) and electronics selection
Hello,
my friend asked to find wings/set for him, he interesting in (universal) foil assist build based on 6384/6374 Flipsky waterproofed motor for 3-5 months trip between 5 countries in Asia (for use on foil, supboard and kayak). His weight ~85kg.
He can’t take/buy efoil or board due long trip between 5+ countries. Daily rent of subboard/foil on planned locations is 25-35$+ per day so his choice to buy own set and take in luggage motor + esc and must + fuselage + wings. He not sure about board at this moment, maybe inflatable Gong or he will buy on the place.
We have Flycolor 150A and Seashark 200a ESC, and looks like any remote could work with them. The 6-20A/h lifepo4 battery under question because most air companies restricts more than 15 separate elements (but 16 required for 48v lifepo4 build). We already find battery build services on final country.
What wings we need for foil assist build, as I know that must be wings with HA ratio? What the minimum required for ~85kg beginner? I found a lot of wings like Axis ART v2 999 but they all to expensive, so we looking for some “middle” aspect wings and sets (budget is 400-600EUR for set).
I found very cheap (only for 100EUR) F-ONE FW IC6 950 V3 front wing - is it small for such build?
Area: 965 cm²
Span: 65 mm
Aspect Ratio: 4.4
Weight: 1.33 kg
We also found cheap full sets from Aztron (and they common on ebay/Ali for ~300USD in Asia area, or even used for ~200USD), like
400EUR Aztron ROCKET 1800H COMBO (1800+300cm²)
350EUR Aztron ROCKET 1650 COMBO
300EUR Aztron ROCKET FOIL 1450
but I’m not sure about their quality because found some comments that their wings brakes very quickly and they also not HA
I have two of RL boards masts, but didn’t find HA wings on their site - must contact Rene @kiterr for clarification, his topic here New RL efoil wing - #41 by kiterr
Update: he has HA wings!
Axis sets is too expensive, over 400EUR for one wing and 1200EUR+ for full set.
Also I found some from Gong https://www.gong-galaxy.com/en/products/gong-foil-allvator-setup-wing-x-over?variant=48102960070975
469EUR Wing Foil X-Over Alu XL
  • Mast length : 85 cm
    Front Wing:
  • Wingspan: 95 cm
  • Chord: 22.0 cm
  • Wingspan²/area ratio: 5.4
  • Thickness: 2.5cm
  • Volume: 2.31L
  • Projected surface area: 1656 cm²
  • Extrados surface area: 1720 cm²
  • Felt surface area: 1650 cm²
  • Wingspan: 48 cm
  • Chord: 8.0cm
  • Wingspan²/area ratio: 7.0
  • Thickness: 0.79cm
  • Volume: 0.15L
  • Area: 335 cm2
Or I must check NSP brand with AIRWAVE 1700 SET for example for 450EUR?
https://eu.nspsurfboards.com/products/airwave-1700-set?utm_source=Dropdown_menu&utm_medium=Referral&utm_campaign=NSP_International&utm_content=Dropdown_menu
Which not too expensive wings/sets you could also recommend for 85kg rider on 6384/6374 with ~1000w load?
We have ~3weeks to order wings/sets in EU before his vacation or buy required components in SriLanka/Vietnam/Philippines.
I was absent on forum for 2 years and very confused with selection right now
If you’re just starting out, I’d totally go for this model: Naish Carbon Foil System.
You can pick the size that vibes best with your buddy’s style.
Oh, and btw, they’ve got a non-carbon version that’s easier on the wallet. :rocket:
Buy used Axis off Facebook. I got a full PNG1150 setup for £650. There loads of other used deals about…
I bought direct from Gong for the curve xl set and 85cm mast. Very nice and the mast has enough room to put the 3 phase wires plus water hose if you need. Gong has a big choice to mix and match if and when you want to fit a different wing or stab.
Just checked available electronics components I have and which I need, and wondered if I’m correctly calculating all components.
Have questions regarding config:
config:
  1. Amass XT90-S anti-spark connectors
  2. Expected, 36v lifepo4 battery, 6-12Ah
    10-30A / 60A max pick
  3. Car Switch Circuit Breaker (100A, 150A)
    5-50vDC, 100-150A
  4. Flipsky 6374 Motor 140KV 3600W
    Max Current: 75 Amps;
    Rated current I/A: 50Amps
  5. not ordered Makerbase VESC 75100 V2 84V
    working current 100A /120A max
  • Questions:
    100A working current for VESC is total for motor+battery OR max for one each of them?
    Seems Makerbase 75100 will fit my config at all?
  1. not ordered Flipsky Antispark Switch Pro V3.0 280A (heatsink)
    Continuous current: 60A (with heatsink)
