Seems ambitious (and fairly un-googleable…) They are now accepting $100 refundable pre-order deposits
https://www.getfoil.com/order-v2/
Thoughts?
Thoughts?
Overall this brand looks like an exciting newcomer. I hope they can deliver at this pricepoint.
Here are some things that caught my eye:
That’s the founder’s main business - this is his side-project:
What is a Maverick Direct Drive motor?
Looks like they will be booking demo days in South Florida mid-March. Very curious to see what they are building and how it compares to what’s on the market already.
A few updates based on their recent Facebook posts - also appears that only the top end $7k version is full carbon (mast + sandwich board, I presume):
We spent two years designing, building, and testing our own proprietary waterproof connector. It screws into the battery directly from the mast via a hole in the board cavity. The only visible wire in the entire product. Its so strong that it also acts as the emergency teather for the battery if it were to fall out. This connector is made in the United States.
The boards have no electronics in them whatsoever. This keeps the cost down and allows you to swap into a new one in literally no time if it gets damaged. They are as replaceable as any normal surfboard. There’s lots of spare room for your wallet, keys, phone etc in the board cavity.
The controller matches the color of your board. The controller is pretty cool. It has a full color display, gps, accelerometer. All the normal stuff. But it also monitors the waterproof seals in itself and the battery. If the seal on a battery is damaged the controller knows that the pressure and humidity within the battery casing have changed and alerts you to get it serviced. It also tells the battery to no longer accept charging from the charger. That alone prevents the majority of battery fires that can occur. The controller is made in the United States.
The entire product has just one button. That is on the controller. Just push it to turn Foil on and off.
The controller attaches to the battery with magnets. It’s a nice place to keep them together when it’s not being used or it’s being transported. The battery casing shown here is a prototype. The final casing is soft rubber.
The controller charges wirelessly when its resting on the battery.
If you want to swap batteries just tap the controller on the battery and they connect. No crazy pairing procedures.
The battery is assembled in th United States.
The battery is 50aH. The largest ever for an eFoil.
“battery has a phase changing material that surrounds the cells. As the cells heat up the material surrounding them liquifies and absorbs the heat. When the material cools it turns back into a solid again. It “changes phase”.”
“the computer is in the battery. The battery is both the brain/battery and the controller charger all in one.”
