@rttn where did you get the print for that stand? @gzmann@lishine I’ve gotten these 100A cells which hopefully won’t heat up as much due to the graphene… I’m hoping that with large surface area wing at 2200cm, It’ll require less power to stay up on foil even if efoiling. I will save this for a later build but that would require a welder and such. @toto44 got some STL to share??
Never happen. I’ve never used the front circlip. I pull the rotor/prop off before loading it in the car to prevent breaking the prop. It’s quite a tug to get it out.
Does anyone have a suggestion for a strap that might fit this new motor mount. I printed it off and all seems to fit well, but now looking for a strap???
Toto44 and Strongarm – which strap worked for you???
Ya it just keeps the stator from rotating on the black housing. The black housing has a slot that the pin goes in and then just line it up with the slot in the stator.
Any one have any wise ideas?
This is the alienpower 6384. Great motor if I can get it apart and resoldered… That will also mean I can waterproof it a bit better.
