KDParts pod and props
I went out on my foil drive this morning first time since winter I’m having an issue with motor cuts out if I try and give 3/4 throttle it stutter’s. Could it be a solder joint. But why only when under load and over half throttle?
They use the flipsky with integrated anti spark in the gen 2 max.
fsesc-6-7-pro-based-upon-vesc6-with-aluminum-case
