One For me, Thanks.
Eran
Do we have any logs for this available?
Good Day,
I will take two. one 6" and one 7"
I have a flipsky 120KV and 100kv 12mm shaft with 8mm threaded end.
One for me too…
Hi, what esc do you use for the flipsky 120 kv ? I just got one from banggood 120kv for 286USD…
this is becoming quite a big order of props
I have the Trampa 75/300 and Flipsky FSESC 200A 60V. I have only bench tested my motor with the Trampa so far. I am still building my efoil so I have not been in the water yet. There are many efoilers using either of these ESC’s and having success. I have built a 12s 14p battery that I will use with the Flipsky esc and eventually I plan on building a 14s14p battery to use with the Trampa esc (second board build.) Consider what battery voltage you plan on using and match your ESC accoridingly. 12s=44V 14s=52V.
We produced each week 100 props…
So this its small for me
I also want to order one FR prop
Thanks, i have already the parts, just need to put together. Inflatable board Flipsky esc and also a 400a Flier. will use some lipo’s 12S. I just ordered from Banggood yet another 120kv flipsky motor as i managed to get from 280USD…And it will fit with the FR7inch prop…
I also would like one, for maytech 12mm threaded shaft
Please add me as well for flipsky 12mm shaft
@alexp I think you might want to doa little search on the foruma nd move the above post over to:
Also @Flying_Rodeo I’ll take one!
@Flying_Rodeo: Sent a pm. I’m ordering a prop, 65162, threaded shaft, 100kV motor.
I think i’ll need 7” pitch.
So for me a 6 " blue if possible. I order a 120 Kv Flipsky motor, 12 mm shaft with M8 thread.
Thank you.
Can you give us the current price ?
for me a 7" prop, 12mm shaft as well please;-)
What IS THE PRICE PER PIECE?
In the past they have been about 150 Euro and 20 Euro for shipping to New Zealand.
Once @Flying_Rodeo, David has approximate numbers he can let us know what sort of discount he can offer. I would like a 7" pitch for the flipsky if you are doing the 7" David.
If you think you want one, just put your hand up for one. Someone else will buy it if you dont go through with the sale.
I’d love one for 12mm 120kv
