Hi David,
1pc 7” for me please.
Any possibility of gettong the folding type?
Br,
Mattias
Hi David,
Br,
Mattias
I’ll take one 7" prop please!
An endcone with some small 10” pitch swirl fins add another 5% efficency to an all ready amazing prop!
I would like one as well for the 12mm 120kv flipsky motor
+1 with 10mm bore and 7in
Hello,
One for me, flipsky 120kv, 12mm. Can i order propeller duct and hub gor flipsky as well?
Use a calculator. If WE assume 48volts and 15% Slip it would give:
100kv = 4800k rpm with 6inch = 43 km/h
120kv = 5760 rpm with 7inch = 45 km/h
Ofc there are losses (duty cycle, not reaching full rpm, drag from wing…) But the ideal scenario are similar, I like it. By the way if you put 7inch on 120kv you will have 51km/h minus whatever is missing. I am looking forward to the logs
Hi David,
One for me please, motor flipsky 12mm 120kv
thanks
Hi David,
I’m also interested by one propeller
Thank you!
Count me in for one 6" and 7" Prop for the 12mm Shaft.
Hello, also interested in a propeller ( blue ) for my 2nd project.
No engine yet, I plan to take a Flipsky. Can you advise me on the KV (100 ou 120 ) to choose and on the axis to take 10 or 12 mm.
It seems to me that only the 12 mm on the Flipsky site is threaded at the end of the shaft … correct or not ?
Thank to all members of the forum for your advice.
Hi David,
Two for me please for two flipsky 120KV.
Thanks !
I am interested in one too
guys how much does one piece of FR propeller cost?
I also take one 6 "color yellow or gold. I have a Flipsky motor, 12mm shaft with M8 thread.
Hello this its old… im realy sory i have no time to update site
and how much does 3 blades cost?
