Hey, all good. You said we will be able to get some props in fall. Its not fall jet, so everything is easy. Good Luck with building you business
Seems like a problem occurred when you uploaded the picture, it’s blurry. Maybe can you share it again
It was done blurry deliberately. This will be something new from FR. I do not know for sure but I am hoping it will be a ground effect wing? for short air flights ??? That’s just only my guess based on the name "FLYWAY. Maybe part Hydrofoil / part hovercraft like https://www.youtube.com/watch?v=CTM8rcA7c04
Just my guess by following a few breadcrumbs in the wind. But if I had unlimited time & $ this is what I would play around with.
Ahah. Yeah I knew it but thought it might work if I asked this way
As for the Flyway project itself, it looks more like a jet ski with wing sets to fly above the water the way efoil does, but with a seat and greater power / speeds
Or more modestly, standing or sitting position:
Hello,
In 2-3 weeks will be ready props for flipsky / mytech motors ( 12mm shaft with thread)
Only for info please send me how many you want…
More orders more discaunt
1-2 ( 5% discaunt)
3-5 (10%discaunt)
@Flying_Rodeo
How about 7 Inch prop? Old Rodeo with 12mm Shaft mount. Would Love it! For all the 100kv ppl
Regards!
+1 on 7” prop. Already have the 6” and it ends at 39kmh with 100kv.
I would go for regular or folding 7” in a heartbeat.
/Mattias
I’d like to buy one for 120KV 6" and one 7" for 100KV.
I take one. can we choose color?
I have the 120kV
If you Use fatal voltages, yes. I prefer 12s
I will take one, 10mm bore preferred.
Guys, which flipsky motor would go better with this prop the 100kv or the 120 kv ?
No, I use 14s and reach 39kmh@95% dutycycle with my modest 130kg frame&rig. 40kmh is 99% dutycycle and unrideable…
Consensus is that >60v is lethal range, but I’m seriously thinking going 16s if I can not get my hand on a proper 7" prop soon.
Too invested in several 100kv:s unfortunately…
Will take one, 12mm 120kv flipsky
Hi David,
One for me please.
Thanks.
I will do alsoe 7 inch for you
Interested for the difference between the
Flipsky 100 kV with the 7” propeller
and the
Flipsky 120kV with the 6” propeller
Hello David,
I’d like to do 2 please.
Edit; one 6” and one 7” to compare:)
we are already over 5 orders. Do we get 15%?
