Not only does David make amazing products but he messaged me after reading my post and offered to send me a new prop to replace the one I lost! Thanks David!
David said they donât have problems with the props coming off because they use a soft start on their ESCs. Customers who buy just the motor tend to have this problem if their ESC isnât programmed properly.
Wouldnât call a soft start to solve this issue âproperly programmedâ. A prop should not work itself loose, period.
what kind of inserts do you use for fixing the mast that are so low?
HULK prop its COMMING
⢠25 % more surface area
⢠diferent pitch 6 and 7
⢠conical HUB (less drag)
Alsoe FOLDING PROP for all FLIPSKY lover
Stay tuned
Fly fast and stay dry
My whole motor axle is moving half mm front and back. Check out video: https://youtu.be/wW6ui66Su8Q
Is that something to be concerned about? Should I open motor and check bearings?
Please dont open motor, this its normal.
Just Fly high and stay DRY
