Hello builders!
In august this year i started my end school project e-foil. I bought the complete foil from RL boards @kiterr . Got it on friday. The quallity of the wings is insane. Everything is visible in carbon fibre, the mastplate already has holes for cables.
On wednesday I ordered hgl tech 65162 100kV version from firduo. (Cheaper than flipskys)
For the prop: Not made decision yet…
For the board I got myself a sponsor (flikka-boards) and for right now I am shaping in 3dshape design pro software. In october we will slowly start production of the board (cnc).
-board will be ~67l
(Will upload pics after I get home)
-plan is to have mostly waterproof costum made hatch using carbon fibre and inside seperate waterproof boxes for electronics
For the battery I will use 18650 cells. I think config will be 12s12p. I dont know what cells i am going to use yet. I will design case for batt (will try to do something like lift), and than have it wrapped up with carbon.
For esc I have flipsky fsesc 6 60V 200A.
For water cooling I will use pressure from the motor holder.
I am designing my own remote. The case will be simmilar to @Hiorth . Their code was never seen by me, so had to code new one, but optimized. The plan is:
-will be using 2 esp32s
-the communication will be by ESPNOW ( esps new protocol, highly optimized, no delay, long range, cant nearly compare to bte)
-tft display on top with vesc info
- the code is almost done, I just have to add the hall sensor, and vesc Uart to the code.
Stay tuned for updates!
