Hey everyone,
I’ve been lurking on the forum for quite a while and have found tons of inspiration here—now I need some direct advice!
So far, I’ve built a few pumpfoil boards, rear wings, foil assist and even two front wings using a 3D-printed core that I laminated over, with decent results. This time, I tried something different: a high-aspect pumpfoil front wing with a 1291 mm span (~1200 cm³ volume, similar to a Fireball 1250), incorporating UHM UD in the layup and using a 3D printed split-mold approach for the first time.
What happened:
I laminated both mold halves (top & bottom), then poured Sicomin PB170 epoxy foam into the mold, clamped it shut, and tried to cure in one step.
Unfortunately, the wing broke after a few attempts. The foam never expanded correctly in the closed mold (almost closed,… two vent holes 8mm at fuselage mount), and it didn’t bond the two halves properly. The leading and trailing edges ended up cracking.
In further dry tests, the foam just doesnt expand in a closed mold. it didn’t generate enough internal pressure to fill the cavity thoroughly.
I still have these 3D-printed molds and would like to reuse them. Ideally, I don’t want to do any additional external laminations afterward (but I’m open to suggestions). I particularly need a robust leading-edge connection or strong enough bonding of top and bottom.
Questions / Looking for tips:
- Single-shot vs. Multi-step
Should I laminate each half separatly instead of closed mould and inner pressure?
- Bridging Fibers
How do you run ±45° or continuous fibers around the leading/trailing edges to avoid weak seams—especially with a split mold that makes it tricky to wrap fibers over the edges?
- Epoxy Foam vs. Solid Core vs. PU Foam
Thought about PU foam instead of Epoxy Foam, but too brittle? Also saw many videos of failed closed moulds surfboard design with lots of airbubbles and other issues…
- Bladder Molding
Anyone tried inflating a bladder in the closed mold first, then adding foam or a core afterwards?
- General Best Practices
Do you have a proven process for building front wings (especially high-aspect) or masts in a split mold so that everything bonds correctly, particularly at the leading edge?
I’m aiming for a stiff, reliable wing without major added complexity, but I’m open to doing multiple stages if needed. I’d love any insights from people who’ve gone through a similar process or know how manufacturers tackle this.
Thanks in advance!
