Germany: Assist project and boogie parts for SALE
As I want to go in a different direction with my next build I’m offering my hip-bag assist and some parts originally planned for a tow boogie. I’m open for offers and custom packages - please leave me a PM. Location is south of Germany - shipping needs to be checked individually.
Disclaimer: All of the items for sale will be sold without any warranty or extended support. I’m not a business and cannot cover any of this. You should know what you are getting into and be able to do your own improvements on these prototype-stage products. Of course I will share my CAD designs with the buyer
1. Hip-Bag assist kit - I’d start at 700€:
The build is documented over here. Originally I started with a waterproof Flipsky 6374 which turned out to have to little torque. Therefore the kit includes now a basic 6384 with DIY waterproofing in used condition. We can negotiate on another unused spare motor if interested. The kit includes the following items:
  • Indiana HP Alu Mast Charger 75 cm with press-fit DIY mast base
  • BDUAV 6374 Motor in used condition - without foil drive prop!
  • Sequre 12200 ESC potted in expoxy
  • Maytech remote with receiver potted in silicone gel
  • self-made hip-bag, waterproof bag with integrated cooling plate and Fidlock quick-release
  • Philippi cable with neoprene flotation sleeve and dyneema strain relief connected with Pflitsch stainless ip68 terminals and second layer strain relief by hose clamp
  • 12s2p Battery made of BAK N21700CGP 4000mAh cells half-potted with SUB-D balance connector and temp-sensor, adapter cable to JST XH included, temp-sensor fits the Icharger X12 and compatible
  • one set of spare spacers to build a second battery printed in SLS nylon by JLC
2. Two Kits of Bremote V2 - each 100€ without BEC/ 110€ with BEC:
Both tested and flashed with SLS nylon printed housing by JLCPCB
One is ready for potting the other one is electrically completed for testing but not yet assembled. One BEC is available as well. Two small parts where not possible to print by JLC so they are basic FDM PETG.
3. Propeller-king three blade props for Boogie, counter-rotating - together 220€:
Not used at all, great quality and surface finish. Fitting the Flipsky 6384 waterproof with flat flange surface or any other 6384 motor with a printed adapter.
4. Indiana M-AR/ Ride foil set - price dependent on kit configuration and if together with foil assist:
I have the 964 and 754 front wings, one stab 370, 710 HP fuselage and 75cm HP alu mast available.
Update
  1. Hip-Bag assist price update: 600€
  2. Bremote Kits 90€/ 100€ with BEC
  3. Propellerking Props 210€
  4. Indiana Foil sold
