Gong V2 mast bottom piece
Hi DIY legends,
I need help with a measurement for a Gong setup. Leading edge of mast foot to leading edge of first fuselage hole. (please use a calliper)
If anybody could help, that would save me 4 weeks of waiting on a pre-order and full blown insanity.
Thx so much.
Best I could do. My adapter is stuck in the fuse so hope this stops the insanity :grinning:
Thanks for that Foilguy, I’ll work with that so long but if anyone else ones to double check it with the adapter out that will be appreciated too.
Your welcome
New participant here @Jacob posted today that he just got a V2 mast. Perhaps he will measure for you. :grinning:
May I ask what you are fabricating that you need the measurement for?
Custom adapter to use gong fuselage on my Armstrong alloy mast. I know Gong masts are really affordable but I really like the Armie mast.
Actually if you wouldnt mind trying to measure another way since yours is stuck. If you put a m6 bolt through the hole and use the inside measurement of the calliper prongs to go between bolt edge and adapter pocket edge. That might be more accurate in your case.
Thanks so much
aha, okay thanks so much
Have you received all the measurments you need? Otherwise I can help
Hey Jacob. FoilGuy has kindly provided me the measurements but I wouldn’t mind a 2nd look because his was stuck in the fuselage which limits your ability to get the claws of the caliper in a good position. I also still need a diameter of that front hole.
Thanks for offering to help.
Hey Larsb. I sent you a pm yesterday not sure if it went through since this post was deleted?
I got it :+1:
I’m back home tonight, i’ll contact you then
I will be sure to check when I am home again
From @Jacob thread
