First post here and I hope its not a duplicate, but I could not find the answer when searching.
I just got my Gong V2 mast (and wing and fuselage) and it seems like the two holes though the mast is filled with some kind of rubber/sealant in both ends. I havent had the time yet to see if it is only plugs in the ends or if it goes all the way though the mast.
Was everyones elses Gong V2 masts like this and if so how did you get rid of the rubber/sealant?
The plugs on the top are easily removed by gripping with needle nose pliers and pulling out. The ones on the bottom can be left in to keep water from intruding. The holes in the side of the mast for motor wires can be made just slightly above where the bottom plug ends.
Perhaps new to building efoils, but I am a mechanical engineer who work with product development I naturally appreciate all the help I can get though! Thanks!
