Hadou Tow Boogie "Tori-Tow V1" Build
Have a look here for some general comments I may have made, the primary issue is the boogie doesn’t handle any chop, but otherwise it’s a good starting platform. Use a bigger board and bigger foil initially if you use the single 6384
Hard stuff
Soldering thick 10AWG cables is a pain, as is soldering xt90 connectors. Tutorial, patience practice. Wooden jig for soldering to reduce heat dissapation
If confident, soldering all wiring except batteries will create a much more reliable and simple system, otherwise things bounce loose
Balance and positioning of the weight and prop and tow is essential. Plan on experimentation to trim and balance
Minor
The heatsink is essential otherwise too much heat build up. Requires cutting a hole that a dremel would be useful for
Heat build up will cause issues, run short wiring in the box and exit the ESC cables as quickly as possible, use 1 cable gland per cable
Great, thanks for the advice!
