Hallee Foil Assist Build - The Hatch
Hi everyone,
Last year, I built an external top-box foil assist unit, drawing a lot of inspiration and ideas from this fantastic forum. Most of my local riding friends are using Foil Drive Gen 2 systems and have built inset boards. While those setups have their strengths, I believe they still come with a number of limitations. That got me thinking — and sketching — about designing an internal foil assist system instead.
Over the winter months, I brought the concept to life. Now that the build is fully complete and tested, I thought it was time to share it with the awesome community here.
Build:
  • 80x50x2mm aluminium section
  • 12s3p battery with external balance charger
  • Matech V3 remote
  • ESC Sequire 12200 & Kontronic Jive 120hv
  • Flipsky 6374 motor
  • 5ft3 board 19.5 inches wide with hatch at rear for assist access
  • integrate aluminium mast
The Housing Build:
• Constructed from a 620mm length of 80x20x2mm aluminium extrusion
• End Cap: Initially 3D printed, but due to flex and sealing issues, it was upgraded to a machined aluminium version with a silicone gasket for reliable waterproofing
• Motor Wiring: Plug and socket are integrated into the end of the housing, with cables routed internally through the board’s mast connector on the underside
• Finish: Experimented with home anodising for both the tube and end cap to improve surface hardness and resistance to the harsh saltwater environment.
Motor cable and antenna from plug:
Anodising the aluminium parts:
ESC and Maytech unit.
  • 3d printed with aluminium heat sink.
  • Removable from aluminium housing.
Built 2 units one with Sequre 12200 and one with Kontrinik Jive 120hv
Battery build:
12S3P battery which fits the extrude just - needed to use copper bus bar instead of cables.
3d printed housing
That looks more like a 80x40x2 section?
Nice , 100% the way to do a built in assist build.
How are you doing your mast mount? No tracks, just enough room for the bolts either side of the extrusion to the top of the board?
@Jezza It’s 80x50x2, would have been nice to have gone 80x40x2 but could not get enough clearance for components.
@Strongarm I have 4mm carbon plates on top of aluminium section that has m8 large head nuts located in the plate. M8 studs then run down side of aluminium. Carbon plates give a super stiff connection. I’ll post some pics later
Potted the end of battery around Xt90 for an element of mechanical and moisture protection. Also added silicone conformal coating on cells ends:
The board build:
This being my first board build so steep learning curve with plenty mistakes along the way.
