Once I had the carbon rods set in, I was able to jig it up with a few levels and get it registered to the mast correctly. I epoxyed it in place and let it set as a first step.
After that Ryan from LAFC came over, masked up, and got to work cutting 15 pieces of 6oz carbon in progressively narrower strips.
We used a wet out table to saturate but not over saturate them with resin. Then we laid then on the mast with the narrowest pieces filling in the deepest part of the repair.
Then we bagged it up with some Stretchelon and attached my reversed aquarium pump vacuum rig. You can see the peel ply (blue) the breather (white) and then check out how stretchy that bag is around the prop.
Once it came out it was mostly done. I did some sanding and cut off the excess at the back and then gave it a hot coat.
I didn’t like the bumps so last minute I sanded the hotcoat down and did another to get it nice and smooth. I’ll try to get a pop if of that this week. But it’s solid as a rock and back in the water!!
