How to secure motor cables to vesc outside of enclosure
Hello guys. On my first build currently…curious how do you guys handle the connection between the vesc cables and motor. Since they are going to be out of the enclosure, what is the best way to make them waterproof? I have a marine cable that will come out of the enclosure through a gland but not sure how to go about connecting the motor cables outside the encloure.
I am using the 65121 motor and the cables are pretty long.
Ive seen a mix of ideas around, some people dont care and they just let them have water contact and others have them inside the enclosure, etc.
One option I’ve seen on a few builds are waterproof junctions like these:
I think it can fit around the those bullet connectors and you would leave out the little wire corrector that comes with that particular housing.
I noticed them recently here:
Thank you, I will try those!
AU$3.36 2% Off | IP68 I/Y/T Shape M20/M25 Waterproof Connector 2/3/4/5 Pin Screw Terminal Adapter For 6-16mm Cable Outdoor Wire Connector DIY GO
https://a.aliexpress.com/_mPpFfNc
