I’m looking for ways to improve antenna signal strength (Maytech) on an underboard assist.
The first version had it placed a couple mm below the lid of the unit in some magic gel. This didn’t work very well and often lost signal. Particularly when starting.
I tried filling mast tracks with a 3d printed insert to reduce the amount of water between me and the antenna position. This had almost no impact.
I tried a poorly placed and tuned antenna extender, but that didn’t improve things
I have now attach a longer antenna lead. But this is fragile and requires taping everytime.
A few questions:
Has anyone tried giving the top of an underboard unit a little hump that houses the antenna? This hump would extend up into the mast track and bring it as close as possible to the surface. While also keeping water above the antenna to a minimum. This has me the most excited due to simplicity and ease of switching between boards.
could the magic gel potting be causing issue?
or should I just revisit the antenna extender with more care?
You have to make sure that the antenna ends are very close to each other. I am still not 100% happy with my solution but it works. For V3 I am thinking of routing the external antenna into the mast track, so I could get rid of that plate.
The magic gel does not break your signal. It’s the housing (if aluminum), carbon board/tracks and water.
