Is my foil setup right?
Hi All, Wasn’t exactly able to find a foil that looked like my Chinese one that I picked up off aliexpress.
I think I have my foil setup like I see in the pics of the foil in the ad. But not sure if it is actually correctly setup. Based on the indents in the foil parts it seems I have it setup right.
Don’t worry… It’s right :grin:
Probably a clone of the takuma v100 , worked fine with me , no worry to have until 35km/h
Thank you so much for the responses.
I have a Flipsky 65161 100kv running on 12s… I tried running it off the prop that came with the motor. I cut it down to 6" and it already had the 5" pitch… Could barely get foiling and when I would. The wing didn’t have stability.
Trying to print some higher pitch props and going to try again…
Mo
