No worries. For now I just made this one fit.
This STL does not fit the Flipsky motor…
Yea. I had to modify it as depicted above. I’m terribly slow with fusion 360, so this was faster for now. I will post the modified STL if and when I get around to it.
But, it’s not hard to make fit. Took me all of 10 minutes.
Ok thanks- I’m modifying mine now… looking forward to the new print.
Did you ever get round to doing this for the maytech 12mm shaft?
Im about to reprint one in PC max, wondered if i still have to modify this with my dremel?
Thankyou. Knew I had seen it somewhere.
Hello
Do you have the “360 fusion” file for the Flipsky 65161 motor duct, thank you
