Bad wheather in Germany
Time to build second battery pack. Again 2x 7S8P to have 14S8P with Molicell P42.
The first same pack with ~1.6kWh gave me on my first 7 rides now a operating time of ~1 hour and something over 17km range.
From where do you order ist I also live in Germany?
Oh sorry i Mean the 21700 Molicell P42
And did you 3d Printet the Holder fpr the Cells by your selve?
Nkon in NL, but they are now sold out
yes, see CAD picture somewhere above
Little update after 4 month of foiling, 2 month of it excessiv
3-4 times a week at the end with trying to jump.
The acrylic frame under the gasket broke at several locations and I had some water inside the box. Not critical because all electronic components are inside at least IP67 boxes, but not nice.
I decided to replace by an frame out of 3mm aluminium, 2mm would have been also ok. Again sealed/glued with Dekalin.
Let‘s see how good it will work. For now it is 100% tight again
It was a great season (still foiling) with estimated more than 3000km on the water ![]()
One highlight was one week with 24/7 foiling on the Eastsee in Boltenhagen in September 2023
For 2024 I want a new board: Smaller, less weight, faster opening/closing of hatch, longer Gong V2 mast with more stiffness.
Build of V2 has started now… see new post
