Hello dearest community,
in my darkest efoil hours I need your help. I have converted one of my setups to bigger motor (before 65xxx) and purchased Maytech 70182 with 120 kv. The motor has 10 pole and quite some torque.
The setup did run well with old motor, 14S batt, maytech efoil remote and different vesc. However, with new motor I see stutter at mid erpm and it wont accelerate anymore. I have tried:
- 4 x different VESC with different FW reaching from 5.x to 6.2
- no issue at start, motor current up to 200a
- no issue in air reaching full duty
- played around (a lot) with flux, resistance and all values you can think of. I have found some suggestion in VESC forum, like halfing KP and KI, but no sucess
- cross checked VESC and remote options with 100kV 65xxx motor, no issue
More confusing: Today I have tried some static testing with small printed prop in water; it was running well and reaching up to 21k erpm with 100a motor load…values I cannot achieve while actually foiling. I did not expect the static test to be successful. My intention was to use it to tune on parameters. Now I am wondering what could make the difference while foiling.
Here is the static test
Here is foiling, stuck at around 17k erpm
I am running out of ideas actually and quite desperate. I bought two additional VESC showing same behavior and spent hours on reworking and testing.
Cheers
