Hello,
Welcome to my build! 2 years ago I set out to build an E-Foil. Bring my past experience form building an electric skateboard has helped a little bit, but to be honest I have learned a lot more since then. I owe a thank you to this community! A lot of my google searching lead me back to this forum again and again. You all are awesome!
I am in United States, Minnesota. Riding on the lakes so flat water and some boat wakes ![]()
This is my first post as I felt the need to do my own homework and research be for asking questions. But now I am at a stuck point and could really use some help. I have taken my board out 7 times making minor adjustments and each time it has gotten better.
Problem is the board will not go up on foil but it does plain. I logged data on my Garmin watch and get to 6mph (Plane-ing out)
what I am noticing:
- It wants to go up on foil but feels unstable.
- I feel like I am at the top of my throttle/rpm
- The nose does not lift hard against me. I am actually very far back on the board but not dragging legs feet. I am keeling on the board at this point plane-ing out
- I feel this speed is sufficient to go up on foil. (please let me know if I am incorrect.)
Please check my build specs and I will do my best to answer all questions.
SPECTS:
Photos will come as soon as the forum allows me to add them. For now Please see my instagram Koolwelds for pictures.
Complete weight with batter 60lbs
battery is 20lbs
I am 160 dry have ridden both with and without wet suit.
Board
5’ home built board foam core and fiberglass/carbon lay-up
Dimenssions:
5’ long
24’" wide
majority of the board is 4" thick
Did some rough math factoring in board shape board it is a least 70 Liters
Complete wing kit with a 1500 wing from Clear Water Foils 1500 Surf Hydrofoil Kit | How to Build a Hydrofoil – Clearwater Hydrofoils
(I do not have many specs on the wing)
- 29" (73 cm) mast
- 1500 cm^2 front wing measures 40" wide
- 17" (43 cm) stabilizer (both top and bottom are slightly rounded no flat)
- 5.5 (2.5 kg) finished
- 90mm mount holes (industry standard)
- Wood frame and stabilizer + eps wing core
Flipsky Motor 65161 120KV
Flipsky water proof remote
FR 2 blade pro 7in pitch
ESC:
Swordfish Pro+ 300A
Input Voltage: 4S-15S Lipo Cells
Continuous Current (Surge): 300A (380A)
Battery: (built by me)
14S8P Samsung 40T 21700 4000mAh 35A Battery (40T3)
12v water pump to cool ESC
Foil and Mast position
Foil is fixed to fuselage at 0 degree rake ( was made to come off but cannot get it off. ![]()
I have ridden with stabilizer at 0 degree and now at possibly 2 degrees down with a washer. I believe this is helping.
Mast has been tested at two positions:
5" between rear of board and mast trailing edge. I noticed that on plane I am kneeling on the back of the board to keep the nose up. If I move forward nose goes down seams opposite of problem from others
I have now ridden it with
11" between rear of board and mast trailing edge. But still can’t get it to go up on foil.
Please any thought into what I need to change to get my board up on foil. I have considered getting one of the Slingshot Hover Glide complete kits but I want to make and educated decision.
