Is there any way to still get these files ? the link in the workshop does no longer work and the direct links do not either… i would love to print these parts
Hello. Can you remember how many layers of fiberglass and what density you used for the front wing? Did you get a rigid shell, or was it flexible, and the wing became rigid after being filled with foam? Have you somehow reinforced the fuselage attachment point? I have a problem with the shape for the bottom of the wing. It has a very small depth, and when stacked, the fiberglass stack is obtained above the shape cut, especially near the trailing edge. It turns out that the two halves of the mold are no longer closed due to the thickness of the fiberglass stack. Did you have such a problem? How did you solve it?
Is this topic still active? It looks interesting although the links to the external site with “the meat and patatoes” infomation appears to be invalid.
Sad to see so much knowledge die when personal sites go dark.
