New Direct Drive Inrunner 65150
Yeah was looking for a 3d printable file. That’d be great if you wanted to share it. At least give me a good starting point.
If not I found a file for the slingshot mast, so was try and draw something up. Mostly been using fusion 360, but not a cad master by far…
Hey guys - this is a long thread, so forgive me if this has already been asked. Looking at this Maytech bundle on Alibaba. Thoughts? What would be the difference between the 100kv, 120kv, and 140kv motors? Thanks!
Hey guys. I got an update from Flier and Flipsky about the compatibility issue with the red 400A Flier boat ESC.
Attached is screen shots of my emails with Flipsky and Flier (Cathy).
They said they are still working on the problem but they have created a new firmware. I don’t have my motor yet. Can someone with this ESC please update their firmware to the new firmware “B_Uart_lowkvmotor” and test it?
Thx!
I am teaching myself fusion360. I have a slingshot mast. I will try to make something. But, don’t hold your breath. This software is slow going.
I suggest more of us learn this software. It is free for non commercial hobbyists and enthusiast’s. Then we can make and modify our own files and share them like @pacificmeister did when he started this forum.
I maintain hope that plenty of files will be available in the near future. I know I plan to share what I make.
It doesn’t have to be Flightjunkie.
If you watch this guys video series on youtube, you will have the basics sussed in about 6-7 videos. I highly recommend them.
I wouldn’t go the maytech route. You can individually buy the components cheaper and there are better components. My biggest issue with the maytech bundle is the motor shaft and prop have been done badly. They should not be using that prop and because the shaft is cut specifically for it, it will limit what you can use.
I’ll see if I can set aside 10 mins today to modify the file for you. It should be pretty easy if all the wire entries line up…
Where can we find the B Uart LOwKvMotor software ? It is not in the list of flier esc software
Here is the basic mast clamp. It will need the channels for the cable to be added in. Slingshot Mast Clamp for 65161 by JezzaE - Thingiverse
Thanks a bunch! I’ll print it out and give it a try. Motor should arrive today as well!
If you print it as is, the motor cables will not run through it. But if you print it at 10% infill you can get an idea of how it all goes together and then measure where and how you need to route the cables.
I have the same set up as you but I can’t get the motor working. There is a single beep and then a 2 sec pause…then a beep again…this continues unless I plug the program card in…then it stops. The remote looks like it connected. If I shut the remote off the board flashes and when I turn it on the red light stays solid. There is 46V at the pack and 46V going into the ESC. The 5V UBEC is also working fine. There really isn’t much to do…any ideas?
Hi Mikel, can you make a video ? settings and connection pls
It should be in the list. Can you update the program? Maybe reinstall it? I will email them and say we don’t see the new firmware.
Thank you. I’ve been watching YouTube videos, but not his yet.
A short update…the 120kv version doesn’t have the torque to spin my higher pitched prop that my geared drive uses. The motors have the same power ratings but the torque just isn’t there on the direct drive.
Time to try a lower pitched prop.
I’ll upload logs a bit later…
Look into the Norway guys build. There is a good clamp. I just added my mast dim (gong foil). Zero infill I will try to fill with epoxy also
Maybe this setup could be suitable for riders up to 150lbs (75kg)… just my 2 cents…
Set up
