Never blindly trust specs from Chinese manufacturers ![]()
I think Peters Design is much more compelling and optimized for our specific use (High torque, low KV, low weight and easy to waterproof)
Has anyone tried this 65150 yet?
No one that I know of.
I ordered one, still waiting on delivery. In the mean, I plan to build the cad for it.
They have good reviews overall on the Alibaba site.
Anyone try their controllers?
Have you received your 65150 Direct Drive Inrunner and tested it ?
Maytech is in the game:
what do you guys think about 9nm Torque and 195Kv?
At $600 for one it’s pretty expensive to experiment and see if it might work. I think it would be in maytechs best interest to send out a test unit to one or two people so that they can review it. If it works well then they will have buyers.
The 192kv is on the high side but may still work.
Some customers pre-ordered motors and I will update news when they receive and finish test.
195KV is standard KV. Other KV can be customized.
Hi Eileen. I have some big interess on you product but with 130kv. Any more info like torque and price for one piece to try please? Yould be the same torque with 130KV? how many pole?
[Edit] As a memorandum, this table will be completed with data provided by @Eileen,
| MAYTECH Motor | MTI-65162-195 | MTI-65162-160 | MTI-65162-130 | MTI-65162-100 | |
| Construction | 18N/6P | ? | 18N/yP | xN/yP | |
| Turns | ? | ? | xT | yT | |
| Working Voltage | ?s-20s (84V) | ? | 40-60V | 40-60V | |
| Max RPM Umax x KV | 16380 | ? | ? | ? | |
| KV | 195 | 160 | 130 | 100 | |
| No Load Current @8,4V | 1.6 | ? | 1.5A | 1.2 | |
| Max Output Power (KW) | 9.1 | ? | j | k | |
| Peak Current (A) | 310 | ? | ? | ? | |
| Max Efficiency | 91% | ? | >s% | >t% | |
| Net Weight (kg) | 2.495 | ? | ? | ? | |
| Dimension (mm) | D65*L161.5 | D65*L150 | D65*L150 | D65*L150 | |
| Shaft Diameter (mm) | D10*30mm | D10*30mm | D10*30mm | D10*30mm | |
| Max Torque @60% | 9N.m | ? | ? | ? | |
| Rating Power | 8200W | ? | ? | ? | |
| Wire Length | 300mm | ? | ? | ? | |
| Connector | 6.5mm | ? | ? | ? |
MTI65162-195:
18N/6P
Max Voltage: 20S (84V)
KV (RPM/V): 195
Current @8.4V without Loading: 1.6A
Max power: 9100W
Peak Current: 310A
Efficient: 91%
Max Torque @ 60% : 9N.M
Rating Power: 8200W
Weight: 2.495kg
Diamention: 65mm *161.5mm
Wire length: 300mm including connectors
Connnector: 6.5mm
The first 65165 motor Maytech advertised on Alibaba was the same motor as reacher tech.
I think Maytech have their motors made by reacher tech so you could probably use reacher techs motor specs as a good guide. But why buy maytechs motor for $US600 when you can get one from reacher tech for $US410.
I hope someone tests one soon.
Thanks Eileen. This first set of data is a bit disappointing.
I am not a motor specialist but the flattering 9N.m is usually given at max rpm (16380= 195x84) and max voltage (20s 84V).
So I don’t know what to expect at half this voltage value since our voltage working range is 12 to 14s (44V to 52V nominal). So it is very unlikely that we can reach the required minimum torque for a efoil use with this 195KV motor as a direct drive = W I T H O U T _ _ G E A R
So, I’m looking forward to your 160, 130 and 100KV data as the max torque increases with the KV going down…
| Johnny Motor | D83-200 | D83-170 | D65L150-100 | D65L150-80 | |
| KV | 200 | 170 | 100 | 80 | |
| Max Torque | 105kg*cm | 115kg*cm | 115kg*cm | 120kg*cm | |
| Max Torque (N*m) | 10.5 | 11,5 | 11,5 | 12 |
If use 195KV for efoil, it will need to use gearbox to lower RPM and increase torque.
Later if I get other KVs test data, I will update here.
I did receive the motor. It is very well assembled. I just have not had a chance to mount it yet. I have been busy with my battery pack.
Here is a video, but my esc was configured for a different motor.
Very exciting moment
How much did you pay for this Reacher Tech D65L150-100 therefore 100KV 6KW motor ?
What will be your working voltage and your ESC ? Any data logger ?
That looks very nice indeed! Very interested to see if it works or not. Maytech is definitely getting their motors from reacher but not at the right KV for efoil which I find quite bizarre…
If that unit works well reacher are going to get a host of orders!
So the motor you are selling and advertising as a hydrofoil motor…that has a machined drive shaft to attach a prop…needs a gearbox. ???
It still amazes me that anybody deals with maytech.
