New E-Foil Build V5.1 - Recycling broken FR Board into a Furi Freestyle
Another E-Foil project finished.
This time I took a different route and recycled as much as possible from one of my previous builds.
My old FR board had a broken mast mount and would have needed a major rebuild anyway. On top of that, I wasn’t really happy with the shape anymore, since it was based on an older design. I wanted something more modern, roughly inspired by the LiftX style.
I found a used Furi Freestyle carbon wing foil board (143 x 59 cm, 70 L) from a custom board builder in Munich. The board already had some repaired damage on one rear corner, so I could buy it cheaply and give it a second life as the base for this project.
Instead of building a completely new battery and electronics compartment from scratch, I decided to transplant the entire internal structure from my old FR board.
What I did
  • I cut up the old FR board and removed the complete battery/electronics cavity as one piece, leaving a few centimeters of surrounding material.
  • Then I positioned the hatch on the Furi board to determine the location of the cutout.
  • After that I cut and routed the new board so the old cavity would fit precisely.
  • I glued the complete insert into the Furi board with a bit of overlap all around.
  • The remaining voids were filled completely with two-component marine expanding foam.
  • Finally, everything was sanded and blended in.
Because I already had the complete inner structure, the hatch, the electronics box and the battery packs, this turned out to be one of the quickest boards I’ve built so far. I didn’t have to build the whole compartment and hatch system from scratch again, the main work was transplanting the existing internals into the new board.
Mast area reinforcement
One special detail on this build is the mast area reinforcement.
Since I had to mill down all the way to the foil tracks/rails area to fit the new box, I decided to reinforce the mast mount area, similar to what I had done before on my Gong board. I bonded in a 3 mm carbon plate to help spread the loads from the mast and foil over a larger area.
That was mainly done as an additional safety measure, but I think it’s definitely worth it structurally.
Setup
  • Board: Furi Freestyle/Freeride carbon board – 143 x 59 cm / 70 L
  • ESC: MGM 250A
  • Mast: AXIS
  • Motor: Lift motor
  • Batteries / electronics: reused from my old FR board
Overall, I really like the idea behind this project: one damaged FR board donated its internals, and one previously damaged Furi board became the new platform. So in a way, this build gave two damaged boards a second life.
Curious to see how this new shape will perform on the water. :call_me_hand:
Here’s the link to the old V5 build thread:
