I just reread the instructions and clearly it says the temp sensor needs to be installed. Anybody know which two wires convey the temp sensor data from a flipsky 200/60 VESC? I’m thinking the 5 pin port using the T and H3 pins.
It is the sensor that come with the remote/receiver when you bought it you shall connect the the two pins.
In case you do not have it any more, you can connect a 10k resistor between the two pins on the receiver.
