Hello all
From now few months I’m using my own remote. It work so great so I want to produce a small batch of 10 unit for exemple. Before I want to know if there is some interests in this forum. features are:
- Remote and board Batterie measurement with gauge for each
- Temperature on board measurement with value on screen
- Vibration in Remote when low bat
- protection when temperature is to high
- built-in RGB led for board status
- Built in GPS and showing speed, top speed and total distance
- power ajustement on remote via user menu (10% to 100%) useful for beginner
- throttle calibration via user menu
- batterie current measurement in board with amps.and amps hours showing on screen
- throttle cruise control on push button
- leash implementation on board (can be ignore with a jumper)
- qi wireless charging
- possibility to change language via menu
- auto sleep mode
- ip67
- lineare throttle
- and may be the most important thing, transmission is done with 433 Mhz instead of 2.4 ghz so no issue with water.
Let me know if someone is interested!
