My design is using small copper sinks to flow ESC & battery heat to wax based ‘heat batteries’
If you are OK with ~50c temps of ESC & batteries you could consider storing the energy in low T melt wax. It is reasonably good with conducting heat & the latent heat requirement for wax to melt might make it a weight efficient alternative to having a larger heat sink.
I’ll be using it mostly because of relative ease of making the system safe & a self imposed design constraint of minimizing reliance and exposure of systems to the environment.
No, I didn’t test the cable glands under pressure. I imagine that coming up with the design for the testing environment might have taken more time than the route I took. My first tests are going to be at the local swimming pool (before opening hours, dah) so the damage is small in case of a leak.
I encounter a small problem with the STL files Prop rev3 - 3 blade and Duct rev3 namely that these are just gigantic and do not match at all the original size …
an idea of where this can come from?
Thank you very much
Thanks @cristophe and @Hiorth
can one of you tell me the outside diameter in millimeter of the duck? because I can not know if when I reduce the stl for printing I am at the right size
For me it is 148,7mm in Cura. I think it is different for @Hiorth because he doesn’t use the same propeller. For me, I use the V3 propeller of @pacificmeister.
I noticed the seal mount file has a REV2 that uses the ceramic bearing for the nuegart ple 40 however the sealmount for the parker does not have this revision. Does the REV2 for the ceramic stabilizer for the parker model exist? Or even a Parker V3.
The Parker assembly model also when you download it has the ple 40 parts. So I can’t find fusion 360 parts to export. The stl were exported in cm instead of mm so their all off and can’t be printed as is.
