Poor power from first build, is it components or software?
I’ve recently gotten my first build to the point where it was ready for water testing (will post full details in a “builds” topic post soon).
Lets just say the performance was underwhelming.
The core propulsion is this motor
  • Voltage range: 8-12S (33.6-50.4V)
  • Max power: 3000W; Continuous power: 1500W
  • Peak current: 70A; Continuous current: 30A
  • Motor KV: 160KV
With this ESC
  • Amps: 50A continuous,instantaneous current 150A
Using the 3 blade aluminum prop that came with motor.
I’m using 2 4s batteries in series for an 8s 12aH pack (rated at 12C)
I charged the batteries up only part way, to 15.75V each (so 30V+ in series).
I’m using the VX3 remote set to 8s, which shows amps and watts.
VESC setup went pretty vanilla with detection wizard - don’t think I changed anything other than breaking current (set to 0) and inverted direction (can post screenshots, or share specific values)
On initial on-water test, I was only seeing a max of 14 amps. I initially thought maybe I had set cutoff voltage in VESC, but (finally getting to the puzzling part) when I tried in a bucket, I initially got similar amps, but as water got kicked out of the bucket, and water level went down exposing top of the prop, both RPM and amps went up to 30.
Is 160KV too high to get torque on that prop? Is 8s going to be too low a voltage to get decent performance from that motor?
I thought this combo would have more oomph.
-P
That motor does not seem like a good choice for a E-foil. 160 KV is a little on the high side, the prop is probably 7.25" in diameter. Takes a lot of torque to spin that prop. !2 guage wires on the motor are small. The wires come out the wrong end of the motor for typical e-foil application. I would try to run it on 12S to get the best possible performance.
You might want to post the screen shots.
Thanks for the input - I’m going to start with just seeing if my 8s pack at full voltage seems to change the behavior, and maybe order a small capacity 12s test setup (I’m using a 6s balance charger, so will just do another series pack - no BMS).
Here are the VESC screen shots, I don’t see anything out of whack, but I also don’t know all the fields.
Note that this isn’t for a full efoil, but an “assist” class device - but one I was hoping to have enough power to get up on foil without a paddle (just not need to use the motor to stay there, for surf/downwind). I posted more details about the build in a “builds” topic:
whoops - meant to post this propulsion update in this topic instead of the build topic (shoulda probably just kept it simple in one topic from the start…)
OK, let’s see how the numbers work out:
160 KV motor, for your max of 33.6V 8s, is about 5.3K rpm (good value for foils)
3000W / 33.6V = ~90A (peak burst current that motor can ask)
sustain would be half of that (1500W rating) = ~45A.
Your batteries are 12000mAh with 12C sustain and 24C burst, so that’s 114A sustain (discharge at 5 min) and 288A burst (discharge at 2.5min!).
I think that’s the problem there. You can (in theory) power this, I think the battery is underperforming here; voltage should sag due to this requirement to discharge fully in such a short time.
Also please not that your max rpm of the motor 6k / 8k = max 75% of the max rpm of the motor (not even close to 80-90% max utilization).
Right…?
I think it’s probably underpowered in several ways but since the vesc current reading is so low then there’s the first problem. Low power in, low power out. I never tuned a vesc so i cannot help with detailed settings but i would try to set drive mode to duty cycle and try again at full voltage. 150A motor phase current (which i guess it is on the flipsky spec) should be enough to get close to the torque potential of that motor if your vesc and battery can supply it.
It seems from the screens that max motor current is set at 44A, this is not enough to power a prop this size when not on foil. Set it at 150A instead.
