Power plug EF8 for efoil battery
let me introduce power plug for eFoil battery
EF8M and EF8F
after 3 years of eFoil manufacturing we are have completed all tests and checks
2 pin, 8 mm banana plugs, gold plated, waterproof
datasheet EF8M EF8F power plugs for eFoil battery
Is that your own design connector? Is it anti-spark as well?
Yes, it is my own design.
Not , it isn’t antispark
These are standard 8mm bullet connectors in an asymmetrical waterproof housing, right?
Is your battery housing ABS?
Yes, you are right. …
Yes. Battery case made from ABS plastic
Do you sell these ABS battery cases ?
no we do not sell battery cases, but we sell power plugs
Where do you get the battery cases from? thanks
we produce it by yourself
In 2026, do you still sell the power plugs ? Do you sell the battery cases ?
