Hello, I have an issue with my efoil. It no longer responds to the remote control. Initially, I thought the remote was faulty, so I bought a new one, but after reconfiguring it via VESC Tool, I encountered the same issue. I’m wondering if the problem might be with the receiver. Sometimes, when I press the trigger, nothing happens, and other times, the propeller spins on its own.
I noticed that the very first time I reconfigured the remote in the software, the blue PPM mapping bars were unstable, unlike in the tutorial video. It still worked for a while despite that. However, the problem has worsened, with greater instability in the bars, which affects the motor’s operation. I’m not sure if my explanation is clear, so I’ll include a video link that shows the issue more clearly. Thank you in advance for your help. https://youtu.be/2WhdRVtNJvk
