I am new to this forum and building my efoil in The Netherlands. I want to use the reisenauer motor chief 6:1 gearbox but it is not in stock, and when I try to order or email them, I don’t get any response. Is there someone on this forum selling a gearbox or can someone help me by calling them? I tried to call but there english was not so good so if someone speaks german that would be great.
If I were you, I would wait a few weeks and observe the inrunner 100-120kv trend blossom… They are direct drive thus very simple to implement.
Signatures to watch carefully: virus and later posts, Jezza, MauiMan, Tizoc, Peter, Bender…
I don’t really know but I read it was out of stock until next year … but I think the super chief might do it … the problem would be to fix the propeller …
Where did you read this? That would be a problem. I have already used the super chief but it is difficult to make a good connection on the gearbox shaft.
@Flying_Rodeo wrote this , and for the connection , see my post , he makes a custome shaft , no problem
For the super chief you can use the propeller adaptor on there site with a 6x7 mm , this bigger but I think it can be done with a thrust bearing
On my last built , the chief gearbox is not even bolt on the tube , and it works and with vesc setting I am not pulling more then 3000w
I also want to order the super chief but find the website confusing , I want 4:1 and it says round shaft is 6x7 polygon? makes no sense when the titles says round , does it come in 8mm output shaft ?
I have the super chief 4:1 with this shaft. It is an oval shaft so thickest point is 7mm and smallest point 6mm. You can choose a 8mm pinion for on the motor with this gearbox.
but they have a round shaft option but its not clear what size that is , doe anyone know what size the output shaft size is in the round version , I was hoping itleast 8mm , thanks or the reply Rienk, have you used it yet ?
I think it is 7mm for the round version but I am not sure. I used it for about 15 hours now. My max power was about 6000w and it is still in one piece. The only problem that I had was the propeller shaft comming of a few times. I grinded 2 flat spots to the shaft and hold it with 2 6mm screws right now.
Yes much stronger , bigger bearing … but if the propeller push on trust bearing , which self center with speed , there is even no needs to « secure » the gearbox , so just the load on the coupler and the gear which apparently hold , and we can use a much smaller propeller
I see you put a bearing around the prop shaft , but no trust bearing ?
