Hi all, usually I like simple stuff so I’m gnna try and make this board as cheap, simple and low tech as possible. I’ll also be posting updates of the small build steps, so hopefully others can view the little tips/tricks and learn from my mistakes.
setup:
radio: maytech v2
prop: propking fold 150mm
motor: 6384-120kv
regulator: swordfish 240A or if that doesnt work the raiden vesc
battery: 4x Turnigy 8000mAh 6S 12C 177Wh
board: homebuild
mast: allvator 80
frontfoil: allvator rise L80
rearstab: allvator stab L
Thanks Toto, but I still have to decide on coating to waterproof the stators before closing it up.
Might go with diluted regular epoxy since there is no heat issue.
For the Stator, I just painted mine. Quaility paint, and that worked for 2 years without problem. To much epoxy on the windings will give heat problems.
Made some progress, changed the bearings to SS for just under 10 bucks.
Double layer of epoxy coating on the stator to keep the rust to a minimum.
Had a friendly garage guy weld the aluminium motormount.
Its starting to look like a Efoil, still waiting for my lipo’s. Next up is the motorcone and board I guess.
That is two layers of Sigmacover 280 epoxy paint ?
You applied it with a brush?
It won’t have heat problems? (especially that you intend to use as an efoil)
What about the rotor?
The motor cone is finished with six layers of 160gr glass, next up painting.
I like to keep it stupid simple so no pump but water ramjet for watercooling of the ESC.
The hose diameter is 4mm and the cone inlet is a coppertube trumped to 10mm.
I’ve calculated that at 30 km/h it should give 1kg of thrust. Thats more than enough to feed the ESC cooling.
Next up is the board.
Gonna be a big mess shaping this
Shaping the board.
With 130cm (4’5") I guess its smaller than most here but I do like light.
Got the big chunks off with wire and orbital sander for the rest.
The shape has oval outlines with a concave deck for snuggy stance.
