SAITE 6384 130 KV — overcurrent cutouts and VESC configuration advice
Hi everyone,
I’m looking for configuration advice. I use a SAITE 6384 130 KV on a tow boogie with Foil Drive propellers.
Current setup:
  • Battery: 13S2P LiFePO₄, 40 Ah, 41.6 V nominal / 47.45 V fully charged
  • BMS: JK, 60 A continuous
  • ESC: Flipsky IP68 Mini FSESC6.8 Plus, rated 150 A continuous
I logged VESC Tool real-time data using a Windows tablet inside the same Peli case as the battery and VESC.
My initial settings were:
At full throttle, power repeatedly cut out with fault 4: ABS_OVER_CURRENT. Around 75% throttle, it ran without cutouts.
I originally chose 98 A absolute maximum because Saite’s datasheet stated “110 A max.” Saite has since clarified that this means battery/bus current for up to 10 seconds, not motor phase current.
The first log recorded peaks of 88.96 A motor current and 34.93 A battery current; it didn’t capture the brief peak that triggered protection.
After reducing Motor Current Max to 85 A, keeping the other limits unchanged, I can take off and foil around without problems. Logged high-load current was around 83 A motor / 33 A battery. ESC temperature stayed below 23°C in approximately 15°C water. I have no usable motor-temperature reading.
I’d like stronger takeoff power for 10–15 seconds. I’ve read the 75100 cut-off discussion and 6384/75200 troubleshooting thread.
What VESC motor configuration settings are people using with the Saite 6384, particularly:
  • Motor Current Max
  • Absolute Maximum Current
Thanks!
P.S: Here is the data sheet shared by Saite team
150A continuos, in dream. That’s may be close to peak.
My expierence with the 6.7 is 50A continuos. Peak maybe 80A for a few Seconds.
The 6.8 seems to be a 6.7 with enclosure? So cooling might be a bit better, but dont expect too much out of those knockoffs
Just my 2ct
ESC is more likely the limiting part.
VESC tool already outputs the guide I think. Absolute Maximum Current should be 150% of Motor Current Max.
Do not have this motor.
But 120/180 should be fine for the motor, for the ESC probably not.
