I’m doing the PM build and am ready to do the final assembly on my drive pod. I have the following questions:
How are the seals and bearings kept in place?
Is the thrust needle bearing meant to rub against the shaft adapter?
The thrust bearing came with two washers. Are you using them?
All tips are welcome before everything is forever entombed.
Thanks!
