We are encouraging all forum members to use their profile as a quick means of sharing build info with other members. Click on my profile pic/logo to see an example. Simply click on your own profile pic in the upper right corner of the screen, then click the gear symbol (preferences) immediately below it. Then click Profile on the left and use “About me” to enter your info as follows:
[build status - observing, procuring, assembling, testing or riding] / [motor model] / [gear model] / [ESC] / [foil] / [board] / [prop] / [link to a thread about your build, if available].
Then, anytime you are on a forum page simply click someone’s profile pic to see a pop-up showing their build specs. Thanks!
Just started collecting the parts - I have a 3D printer (Tevo Tornado). So far I have a Hobbywing 130HV esc - SSS 360KV, 2X 20AH 6S batteries and most of the 3D parts printed.
Done! Completely new to foiling and efoiling, but very excited to have discovered this site thanks to PacificMeister Youtube series! Thanks a lot for all the info shared already!
CIAO SONO Demis SONO ITALIANO E VOGLIO ENTRARE IN QUESTO MONDO ,HO VISTO VIDEO E MOLTI HYDROFOIL E MI È VENUTA LA VOGLIA DI CREARNE UNO
HO VISTO DA VIDEO TANTI MOTORI ELETTRICI E TANTE IDEE PER EVITARE DI COMPRARNE UNA GIÀ FINITA ANCHE PERCHÉ COSTA PARECCHIO , IO VORREI CREARNE UNA SE QUALCUNO MI PUÒ DARE UNA MANO CON LA PARTE ELETTRICA E ALCUNI FILE DI STAMPA PER CREARE LA PROTEZIONE MOTORE : VORREI PRENDERE IL MOTORE SSS 65104 CON REGOLATORE RAPPORTO 5.1 IN ABBINATO ,HO BISOGNO DI SAPERE CON PRECISIONE L ESC DA PRENDERE LA BATTERIA O LE BATERIE PER ALMENO 30 MIN O 60 MIN DI ESERCIZIO SENZA BRUCIARE MOTORE O ESC UNA POMPA PER RAFFREDDAMENTO ESC E UNA CENTRALINA CON COMANDO REMOTO DA 2,R GHZ E UN REGOLATORE DI TENSIONE PER LA CENTRALINA OK .
IL REGOLATORE 5.1PER MOTORE SERVE ?
C È QUALCUNO CHE IN BASE A QUELLO CHE HO SCRITTO HA GIÀ DEI FILE PER STAMPARE IN 3D LE PARTI DI MOTORE E REGOLATORE E DEI FILE PER LA PROTEZIONE ELICA VISTO CHE NON HO UNA STAMPANTE 3D E LO FAREI FARE IN NEGOZIO ,RINGRAZIO CHIUNQUE CHI MI PUÒ DARE UNA MANO
