@Flightjunkie would say fill it to half full
Yep. Put the rotor in then fill it till itās half full. Take your time. The windings suck up a lot of it. Holds way more then you would think. Probably 4-6oz? I donāt know. Sorry, I didnāt measure.
My two friends and I are over a year in with our 3 65161 motors filled this way, used in salt water, and they are still going strong!
I recommend silicone grease on the shaft and o-ring. And Tef-Gel on all the bolts.
Hi Robert,
Where do you find a Corrosion X in EU ?
Itās impossible to find it in France
Hi, i bought it on Amazon ![]()
https://www.amazon.de/gp/product/B01NCEF8FX/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Corrosion X in spray ā¦not in liquid ā¦it might not be easy to fill the engine
hello i buy it in uk for france at a good price
Hi Robert,
Very interested in your builds as we are using same setups.
Please update if the passive cooling works well with the HGL tech also?
ALso is the HGL rated 300A the same as the flipsky 75200? they look very similar.
Any reasons for not soldering the cables in the ESC box?
On the Motor you are very lucky if you see no water ingress. I have just scrapped my first 2 65161:s that was old gen lipsealed. Are you on the never type with Mech seal?
Corr X did not fully help in the long run with lip seal, I usually fill a Schnaps or 4cl.
Mine started to conducted electricity on the shell with terrible galvanic corrosion last year.
Now have 2 Mech seal variants but have not opened them yet, no electric conduction through shell atleast.
I successfully run a HGLTECH HI200 75V 200A passively cooled in an aluminium box attached to an aluminium plate.Motor is a 63100 outrunner, motor current limit is set to 150A, Battery current reached 76A. Max VESC temp was 37 degrees. This was in winter so I assume it wil go up in summer but there is some reserve and you donāt run it on 150A motor current all the time.
Thanks all for the links, Iāll buy 500ml in liquid for my 2 motors 65161
Unfortunately it no longer issues for the European Union
If any of you have another address where to buy for the EU ā¦thanks
Spray. it is the same liquid inside⦠And comes out with the push of a button
What thickness is your aluminium sheet?
It is 4mm thick as it holds the mast, stable but rather heavy, 1.3kg (just the plate).
Manu,
you are right corrosion X UK donāt ship to France
So I bought in Germany with the link of JvdZ
be careful with the UK now, because we pay the customs fees, due to the Brexit.
I paid 70⬠for my trampa vesc 6
70 euros ⦠for 400 grams ā¦
Brexit, I wanted to buy Trampa
I will think about it
This is where I bought mine from.
