After almost one year tinkering on my Efoil I finally have no break downs for the last 10h of ride… This is why I thought it’s time for sharing my -until now- working setup and thoughts.
My idea is to have a propulsion unit were all axial sealing get compressed to aluminum surfaces. Everything is assembled together by long screws in solid aluminum threads. At the beginning I had a lot of 3d printed parts which I gradually changed to aluminum because of water leaks.
Now I’m quite satisfied with it
Enjoy!
link | comments |
Flier 320A | pros: ramp control, max throttle adjustment, not burnt yet (unlike the other 2 Seaking HV130A), auto throttle stick calibration, a lot of settings adjustable, with extra capacitors, not expensive cons: is getting quite hot - until 70 degrees C |
BL Motor SSS 56104/700KV / 10D | with 10mm shaft, no problems yet |
SUP Foil Ican Sports F002 | nice quality, stable, can really recommend , hollow mast, cheap (365$ incl. shipping and second mast (90cm)) |
Neugart PLE40 8:1 | bought two of them unused on Ebay for 30€ each , please don’t ask me for the second one ![]() |
Multistar 20000mAh 6S | I changed the connectors to XT150, survived two fires |
IP67 waterproof switch | recommendable |
Outdoor Case 336x300x148 | no problems so far, good quality, 100% waterproof |
fuser holder mini-anl | only thing that worked for me (fuse: 200A) |
jaw spider coupling | with 9NM, I tried 5 different other couplings before without success, added 2 scrub screws and loctide, spiders with less than 9NM failed |
Hiorth prop V1 | scaled to 160mm, have no comparison yet |
7 1/4 X 5 Yamaha prop | not tested yet, maybe a cheap alternative, 10mm shaft |
2.4Ghz Electric Skateboard Remote | in a condom a nice working and cheap solution |
UBEC 12S - 12V | recommendable |
SBEC DUAL 12s with 12V and 5V | not tested but would go for this one |
Ammeter 200A with Hall Sensor | highly recommendable , easy installation, really good readability in sunlight |
12V Red LED Digital Thermometer | highly recommendable, with adjustable beep alarm, measuring the ESC temp, bad readability in sunlight |
DC 12V self priming pump | I have measured 1 l/min on my setup (water pumped through mast) |
Mini 12V Priming Diaphragm Pump | I have measured 0,6 l/min on my setup |
Ultra Power UP200 DUO AC DC | is not that bad, there are better available |
Turnigy REAKTOR Pro 350W | no problems so far |
military ammo box | recommendable for charging battery |
AS150 connectors | highly recommendable, my XT90 connectors melted, no problems so far |
Wago 221-415 | highly recommendable for connecting the stuff |
85 x 85 x 40 mm box | for tidy up the electronics |
Hydrofoil Wing’s Bag | highly recommendable |
