Hey everyone,
I just got a few rides with brand new Takuma efoil with 1600 wing. This is a great cruising foil, however, I’m experienced foiler so I just want more performance. I have a basic electronics background so I’m thinking of some ways to upgrade the setup.
I’m mostly interested in some off-the-shelf components as I don’t have that much time. Ideally, I want to keep the original ECU, remote, board, battery, and only focus only on everything that is below the board:
- A longer and stiffer mast (Moses aluminum) for more direct feel and flight height.
- Direct smaller diameter motor for less noise and less drag.
- Different wings setups as I have a large amount of Moses wings.
I see the battery is Samsung 48v/35ah ( https://www.takuma-concept.com/93-e-foil-battery.html ). Could anybody point out the direct engine/prop options that would work best for such battery?
