56mm jet carbon fiber
120mm prop aluminium
Nice graph! @PowerGlider
In practice, the propulsive efficiency typically peaks at a level of around 0.8 for a propeller before various aerodynamic effects act to decay its performance
So I suppose the factors should be around 0.8 to take into account the negative effects of a infinite large propeller that of course would be bad. The phd foil guy also told me that a factor of around 0.9 would be ideal, as hydrofoils is a special case where there are more “room” for the propeller. Furthermore after some more calculations and advice from our friend we belive 150-200N thrust is a more accurate estimate. In that case a correctly designed Ø160mm propeller should be pretty good for our setup.
The formulas are really simplified, so I guess they are only valid in “usual” cases, not with infinite large propellers .
@PowerGlider I dont know the magnetic volume, the motor is inside the Propulsion unit now, would be too much of work to get it out just to measure The aluminium casing is 92mm long and Ø58mm if that helps.
Did a small run the other day. This is with 2x6s16000mah batteries. At the end there was 3.70-3.75 Volts left on all cells. The setup is with a 4 blade 140mm prop, rice speed nozzle shroud with 5 degrees AoA and twisted stators downstream of the propeller.
Should definitivly be possible to increase the run time by improving propeller design!
I am planning a shrouded prop, so if the diameter gets too large there are additional grids necessary to protect your foot or fist from touching the prop from the inlet side. The outlet is not protected as rotating blades will not harm anything, because they will repell everything with their angle of attack. This is kind of bloody experience i made with aero props.
My 17.5cm design had two horizontal fins as a grid (in combination with the vertical fin), for 14cm i plan to have a single horizontal fin, please have a look here: Direct drive outrunner with direct water cooling - #79 by PowerGlider - Propulsion System (Motor, Gears) - FOIL.zone
By this i hope i can reduce drag a lot and overcompensate the lesser efficiency of reduced area.
@Hiorth That’s a great looking enclosure. Is the sealing rubber a clip on style or is it glued to the edge of the plywood.
Its a double sided tape, which is taped onto the epoxy and fiberglass coated plywood, works like a charm.
@Hiorth Great job. Did you use a router or a special tool to hollow out the board or did you do it by hand? Also how close did you need to cut towards the bottom of the board? My board is only 100mm thick and I’m concerned that I will weaken the board if I go to deep
We did it by hand with knives, Loads of work! will use a CNC router next time! its about 90mm deep. We have 3 layers of fiberglass on the bottom and walls, the walls will provide additional strength to the board. But I guess 10-20mm (think we have about 20mm) should be left in place, but It also depends on your board type and what type of skin(fiberglass layup) the board has.
Thankyou for the quick response and help @Hiorth Your efforts are appreciated. Trying to find the right enclosure for the batteries is my next challenge. So many that are the right dimensions, but too deep.
Cheers from Aus
Building a box with FR4 plates would give you something that you could customise and it would be fireproof. You could then lightly sand the exterior and epoxy it into the board.
no problem how deep the box is if the walls are strong, my box is without foam.
Hi Jessa, what epoxy would you use to bond to the board
I am based in the UK, so would probably just use this epoxy: http://www.easycomposites.co.uk/#!/resin-gel-silicone-adhesive/epoxy-resin/SuperSap-CLV-Clear-Epoxy-Bio-Resin.html
Impressing drive distance, must be very cold. Nice design, what is the nozzle and prop made of? Can you grind/sand it? You should get some percents in eta by better surfaces.
Can you recommend a modern book about hydro prop design?
The prop and duct is 3d printed in PLA on a 500$ 3d printer. The picture is from an initial assembly, prop and duct are now Sanded smooth and epoxy coated. The prop design on the picture is not optimized at all, we drew it with very limites knowledge of props and no calculations, will start with a thorough theoretic optimization combined with hands on testing now!
Dont know any good books. We just read around on the internet, much bad information, but some gold nuggets here and there, research papers are mainly a good source. It will be interesting to learn more about prop design. Most of the litterature we find is based on large vessels, but we think It translates pretty well to our use.
Hi, you think to share your V2 files? Ho you fix and waterproof the screws on black alu pipe?
Giacomo
V2 is not ideal for DIY as its milled in aluminum, the seal is done with standard O-ring grooves, similar to the what @pacificmeister uses on his design. V1 is out and is a good starting point and people can do modifications as they like.
